View Full Version : Konica C6000 needs help
cxtqd
11-24-2019, 05:49 PM
Images printed on Konica C6000 machine are distorted, Experts please show how to fix them, thank you very much
Phil B.
11-24-2019, 05:55 PM
hold on my crystal ball is warming up......
there...
what size paper?
what feed direction?
what tray are you printing from?
are the paper guides on the tray tight to the paper?
what are the condition of the feed and image parts?
you really need to provide more info to us for us to lend aide ...
I'm sure the other guys/gals here will need other info too.
cxtqd
11-24-2019, 07:57 PM
there...
what size paper?
Paper size A3 Plain Paper 80gsm, for all trays
Parts is new
Phil B.
11-24-2019, 08:00 PM
Parts is newGuides tight on paper?
Do test sheet skew the same as prints?
Synthohol
11-24-2019, 09:10 PM
i only see a slight skew in the test pattern, have you initialized and done the both sides adjust for the trapezoid effect?
methogod
11-25-2019, 05:28 AM
hard to tell by your drawing is its skew or trapezoidal.
loop adjusted?
cxtqd
11-25-2019, 10:31 AM
4 corners print irregular
Rohullah
11-25-2019, 04:42 PM
First you have to measure and adjust double side adjustment, mostly this happen in front side. If not solved, check the first feeding roller in right side of ADU, if the 2 roller pressure was not same, adjust pressure of rollers. Rollers pressure are changes when paper jamming in feeding roller.44149
