Bizhub C308 no network setting, unable to connect
  • lukasz
    • Nov 2019
    • 5
    Hello,
    That's my first post over here. I'm trying to solve a problem with my bizhub c308. During changing IP addresses and network setting I must have ticked sth about DHCP{the printer was using a static IP) and now I can't get into the NETWORK setting in administrator mode. I cannot get to the remote control panel either and printers IP doesn't ping. How can I bring back the network setting to default? Service mode can help?
  • dannu
    • Jun 2016
    • 25
    Re: Bizhub C308 no network setting, unable to connect
    Originally posted by lukasz
    Hello,
    Service Mode
    System 1
    Initialization
    Network Clear
    Or
    Utp cabel its work ?
    Network Duplex Gigabit , Half Duplex settings ?
    • lukasz
      • Nov 2019
      • 5
      Originally posted by dannu
      Service Mode
      System 1
      Initialization
      Network Clear
      Or
      No need to have any firmware usb or stuff like that? Cable's ok for sure. It's been working till the network setting changed.
      • tsbservice
        Field tech
        • 7927
        There is no really need to mess up with service mode, do network initialize from admin settings:
        • [Utility]
          • [Administrator Settings]
            • [Security Settings]
              • [Security Details]
                • [Initialize]
        Initializes the settings in [Job History], [Copy Program], [Network Settings], [Address Registration], and [Enhanced Server Information].
        Select items you want to initialize, then tap [OK].
        • lukasz
          • Nov 2019
          • 5
          • [Utility]
                  • [Initialize]
          Unfortunately, I can see security setting in Administrator Settings.
          • tsbservice
            Field tech
            • 7927
            Take a photo of machine screen and upload it somewhere, post the link here.
            Also did you try to restart the machine from main switch?
            • lukasz
              • Nov 2019
              • 5
              I'll do it tomorrow than. Thanks.
              • emujo2
                • Mar 2017
                • 1580
                Cycler power..if ti's in DHCP and you are not utlilizing DHCP it may take up to 10 min for the machine to give up..but once it does you should be able to print a config page..IP address should be 169.X.X.X,,(APIPA) If you can see this then you should now be able to go into network settings (verify that TCP/IP didn't get set to OFF somehow), disable DHCP and assign a static IP.. If you see 0.0.0.0 as the address then you may have some underlying condition that is preventing the newwork tab from popping up. Sometime turning TCP/IP OFF, cycling power then TCP/IP back to ON will reset everything. E
                • copier tech
                  • 8106
                  Hello,
                  Welcome to our site!
                  This is quite common with Konica.
                  Try simply powering off the machine, unplug the machine from the network & reboot it can take up to 10 mins but eventually your network settings/TCIP tab should reappear in admin settings.
                  Sometimes it this doesn't work try plugging the machine into another router that supports DHCP once it establishes an IP you will have access to the network settings again.
                  Last resort perform a clear in service mode but this can cause further issues.
                  • lukasz
                    • Nov 2019
                    • 5
                    Thanks guys, I dealt with the problem by security settings and reseting network. It worked perfectly. Thread can be closed.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      i often wonder if people just dont expect it to possibly take so long because on other brands ive switched from static to DHCP and it takes like 10 seconds to obtain a DHCP assigned address so to some even waiting 2 minutes may seem to long when like you said it can often take way longer than this.
                      i find it like waiting for water to boil, its best to just walk away and not watch it or it will seem like its taking even longer
                      • Bix
                        • Apr 2018
                        • 1421
                        It happened to me every now and then that the printer spent more than 10 minutes.
                        In that case I had to turn it off and on again to make it go correctly.
                        • emujo2
                          • Mar 2017
                          • 1580
                          I'm pretty sure it's not the DHCP component that causes the slowdown. I think it's the ARP request..DHCP is pretty cut and dry, You can see the normal speed by watching a laptop NIC fail to get a address assigned..There is also BootP..which ARP replaced..Not sure why this old ass tech is still showing up..this has been around since before 1985. E
