View Full Version : Electrical Artifacts on C364e on Screen Panel
cayyell
11-28-2019, 03:01 AM
Hi guys
From a perspective of a PC, looks like a dead graphic card or corrupted graphic driver to me.
And yeah, I did swap with a working screen panel and shows the same result.
44200
Is there a possible firmware to fix this?
Synthohol
11-28-2019, 03:22 AM
ok, if you boot to a firmware stick is the screen normal?
cayyell
11-28-2019, 04:07 AM
Nope, just done, still the same distortion.
rrrohan
11-28-2019, 05:45 AM
id unplug the cable at MFPB and reconnect as you have obviously already done it at the touch panel end when swapping panel
cayyell
11-29-2019, 01:56 AM
Nope, tried that didn't work as well
rrrohan
11-29-2019, 02:04 AM
does it still print ok?
cayyell
11-29-2019, 02:33 AM
I am guessing the mfp is dead.
I forgot check that before I accidentally plug-in a NVRAM reset usb.
So the print looks like this now
4422744228
both counter and test print. I am not sure because is this the pattern of uninitialized of the machine or what as I dont remember the counter list will look like even tho is uninitialized. But the gradient print is fine and smooth.
rrrohan
11-29-2019, 03:00 AM
might be lucky and it just be a problem with RAM but id say MFPB
