View Full Version : Miscellaneous Konica Minolta C454e Paper Jamming
mearmi
11-29-2019, 05:42 AM
Getting Paper jam in C454e With Error Code 30-03 in email and 11 on the machine.
Please find the pics and advise.
Thanks and Regards,
tsbservice
11-29-2019, 06:05 AM
What was done, from which tray, etc. Try to provide more information than average enduser. I'm sure you can do more.
mearmi
11-29-2019, 09:07 AM
machine was working fine . My tech printed 200 books staple folder.
got one client to buy this printer. Bad luck my technician blowered And fully cleaned the printer since it is not working.
as mentioned earlier it was working 100% perfect
Please advise there something happened when he blowered and serviced
i have to deliver the printer tomorrow please help
thanks a lot
mearmi
11-29-2019, 09:10 AM
from all tray same thing is happening
even the paper get wrapped on registration roller
did u see the photos
thanks please help
tsbservice
11-29-2019, 09:24 AM
Have him check reg sensor, is it free moving? Arm and spring on place?
tsbservice
11-29-2019, 10:38 AM
Also if paper makes it past fuser and jam between exit roller and fusing roller it may worth to check paper exit clutch harness or replace clutch: CL8 (p/n A161M20400)
copyman
11-29-2019, 02:10 PM
Good advice. There is a bulletin addressing 30-03 for CL-8 being bad or dirty. Not sure but thought the 30-03 code was when only using tray 3 LCC?
tech51
11-29-2019, 05:05 PM
Well I’d start by putting the transfer roller back in.
copyman
11-29-2019, 10:53 PM
I added the bulletin addressing 30-03 jam in previous post. Didn't want you to miss it if you read it already.
blackcat4866
11-30-2019, 12:24 AM
J30-03 jams are usually caused by CL8 and/or the exit sensor (in one case both). But I would definitely install a second transfer roller. You'll want one of those. =^..^=
