View Full Version : CQ Konica minolta c360i
mayorg
12-19-2019, 08:36 AM
Please can anyone tell me how to enter service mode on konica minolta c360i please
Sent from my SM-N950U using Tapatalk
tsbservice
12-19-2019, 10:00 AM
Use magic button behind the panel. Then same as older models.
mayorg
12-19-2019, 10:04 AM
Use magic button behind the panel. Then same as older models.Were is the magic button locate sir
copier tech
12-19-2019, 10:08 AM
Pop off a small cover behind the control panel.
tsbservice
12-19-2019, 10:10 AM
Behind the operation panel, remove small cover.
Bix
12-19-2019, 06:46 PM
you can enter without pressing the keys behind.
Do as always, Counter can be found in Utilities.
tech51
12-19-2019, 06:48 PM
If you want trouble reset then do the above.
If you want service mode it’s as it always was, counter stop.0 etc etc.
tsbservice
12-19-2019, 07:16 PM
Now I see what a stupidity I was done... this probably isn't one of my smartest days :o
copier tech
12-20-2019, 12:01 PM
KM changed the CE process to stop customers logging in yet immediately after the machine is released its all over the net!
tech51
12-20-2019, 05:48 PM
Not changed though has it?
Service mode is the same as always and the only reason the buttons are on the back of the panel is to keep the front all smooth and modern looking!
xman
02-13-2023, 12:42 AM
Please help with resetting the service mode code.
I have a client with a 360i, previouse service company has changed the code.
What is the procedure to reset or change the service mode code please.
