View Full Version : Miscellaneous Auto Gradation at CE Mode have no value at "Printer" "FEET"
denvertan
12-23-2019, 08:04 AM
I am new to this.
Does the FEET is normal to have no value ?
44457
I read the service manual it just mentioned to redo the Gradation Reading after restart the machine.
But after many attempt still value is ZEROS.
Leyahné
12-23-2019, 11:01 AM
You have to do both
Sent from my SM-N960F using Tapatalk
denvertan
12-23-2019, 12:19 PM
You have to do both
Do both ?
I did both Printer and Copy already.
Attempted many times but it still no value. A few times I started with Stabilization + Data Initialization. Still the same.
qbert69
12-23-2019, 02:08 PM
Do both ?
Attempted many times but it still no value. A few times I started with Stabilization + Data Initialization. Still the same.HIT START BUTTON IN THAT MODE!!!...AND DID YA LAY THE PRINTS ON THE PLATEN GLASS TO SCAN & CALIBRATE?! ....It's gotta have that "feedback loop" to ge the numbers to populate!!![emoji848]
Sent from my SM-N950U1 using Tapatalk
Synthohol
12-23-2019, 10:21 PM
i never see FEET change either, its irrelevant.
srvctec
12-24-2019, 05:06 PM
Yep, same here. I just check the bird test page after properly running gradation and if all looks great, then I'm done with the adjustment. I never pay attention to any of those numbers unless there is an image quality problem that can't be resolved by running gradation.
Woxner
12-24-2019, 10:41 PM
you will get 0's after stabilization. you need to get 30 to 60 in colums 2 and 4 in printer and copy area. it can be minus or positive. dont be concerned about feet.
