Toxic
01-04-2020, 12:32 PM
Have this problem for a long time never have enough time to commit to solve problem.
Machine is Bizhub 950 + FS-611
Machine is in fully working state except when print or copy some job including large black areas in the middle of page then it throws j-7216 all time.
I put to copy 3 full black sheets, face up, 2 sheets come out from finisher then jam occurs and third paper left in fusing unit.
I try to clean, replace photo sensor (fs entrance sensor) from other working finisher,same thing.
I try also to bent sensor plate little bit down so sensor is more close to paper passage but nothing better.
When i check sensor by I/O check manualy it register paper with some full black print but at high speed paper passing it seems it can not register it.
Just to mention,when black area is not in the middle where sensor aiming it goes out without problem.
It looks like sensor dont have enough sensitivity to read reflection from black area on the paper...
Somebody seen this problem,maybe i am missing something?
