View Full Version : Fiery RIP for Konica 7920?
AKSturb01
01-08-2020, 09:43 PM
I have a Konica 7920 with the onboard Fiery PostScript RIP/Hard Drive/Network adaptor that still works...sort of. It starts up normally and will copy from the scanner glass, but the RIP is dead.
After about 1 minute trying to "Loading System" the yellow warning light goes on:
"Boot Failed. No Boot Device."
I assume this means the Fiery hard drive / RIP board is dead.
Does anyone know where I can get one of them? Is it possible to replace it?
Thanks in advance.
Synthohol
01-08-2020, 10:06 PM
Z4 controller or the X3e?
AKSturb01
01-08-2020, 10:16 PM
It's the X3e, internal.
Synthohol
01-08-2020, 10:20 PM
well even though you are not a contributor your rep count vs post count is admirable.
you can use most any laptop HDD to replace and i can PM you a link to the system software disks on my server.
if you need the manuals too let me know, IIRC there is a special parallel to scsi cable you will need.
good luck!
AKSturb01
01-08-2020, 10:28 PM
good luck!
Thank you very much, I'll be in touch.
tsbservice
Lol first color machines I worked on Toshiba FC 15/22 were with that Fierys. Long buried now, but what a memories 💾☎
Synthohol
01-08-2020, 11:51 PM
that model looks like the CF1501/2001 or maybe the CF3102.
reloading system software requires the scsi to parallel cable, some LPT1 tweaks and a whole lotta prayer.
id just set it on fire and run personally ;)
