View Full Version : C258 Set default tray
Hi guys,
I have an issue with the default tray fro internal prints.
For example, if i print the demo sheet of the bird, the tray set by default is the number 2. I'd like for each internal prints, tray 1 be selected. Anyone knows how to ?
i have tested commun settings for paper settings : utility > user settings > system.
I tried in user settings > print settings > paper settings > default tray > 1.
Dunno where...
copier addict
01-15-2020, 01:19 PM
There is a selection that reads "print lists". Or something like that. It should allow you to select a tray from there.
jalaoly
01-15-2020, 02:06 PM
Hi! Guys
user settings > system settings > paper tray setting>print list and choose your paper tray
well i shoud not be understandable.
I know how to choose a tray for an internal print.
The issue is when (for example) i want to print a bird, without touching the screen, the tray 2 is selected.
I would like the tray 1 to be selected (by default).
how to fix that ? (maybe is that a softsw)
jalaoly
01-15-2020, 03:19 PM
ok
if you are on select auto to copy mode and on the printer driver
user settings > system settings > paper tray setting>auto tray select setting
auto tray select=>select all tray excep by-pass
tray priority => up tray 1 first.
tsbservice
01-15-2020, 04:38 PM
I have no idea but if other don't work, you can try this:
[Utility]
[Administrator Settings]
[Copier Settings]
[Specify Default Tray when APS Off]
Select:
[Default Tray] Switches to Tray1.
jalaoly
01-16-2020, 11:48 AM
hi
On copy mode,select tray 1
user settings>copier setting>default copy setting>current setting
kingarthur
01-16-2020, 03:51 PM
When I print the "bird" demo sheet, the machine asks which tray i want to print from.....
emujo2
01-16-2020, 04:00 PM
Print list selection is for test prints, IP config page, PS PCL fonts, fax report..You can default these to whichever tray you wish and posted a few comments above.
Synthohol
01-16-2020, 04:38 PM
plus that tray has to be set to PLAIN.
Issue solved.
Data clear + user settings > system settings > paper settings > tray 1.
At the begining, even if i did choose tray 1, it still prints with tray 2.
Thanks all for your replies.
