View Full Version : c224 error c-2557
refillman
01-15-2020, 03:11 PM
hello
i have this error c2557 which i cant get round
ive replaced the drum and developer unit at the same time about 1 month ago every thing worked great then yesterday we had the error message, iv replaced the drum and checked the brushing, done the graduation adjustment toner is droping,
some times you can print 10 sheets sometimes only 5 the developer was brand new when i replaced it
please help
Darren
Phil B.
01-15-2020, 04:39 PM
hello
please help
Darren
you did intit the dev unit?
OEM Original toner?
refillman
01-15-2020, 04:44 PM
yes oem toner
intit the dev unit.... nope how do I do that, I did do a add toner cycle.
tsbservice
01-15-2020, 04:48 PM
Here, read spock's answer, different model but same faults:
https://www.copytechnet.com/forums/konica-minolta/136479-konica-minolta-c458-c2557-code.html?136479=#post728414
Also I believe front bushings are modified, there's bulletin about that somewhere.
tsbservice
01-15-2020, 04:52 PM
yes oem toner
Newer Konicas are easy on that, you only need to run Gradation Adjust after replacement of dev unit.
refillman
01-15-2020, 05:09 PM
hi yeah i did that when i installed the dev & drum unit every thing went great until i did a big run, then just before the end it started with this error.
ive taken the front panel off and the screw on the black tones is spinning ok
tsbservice
01-15-2020, 05:17 PM
Next one to check would be A161R71122 Sub Hopper Assembly.
copier tech
01-15-2020, 08:40 PM
I've had 2 calls for this issue in the last week both times I replaced this sub hopper.
Check the toner bottle is rotating have seen the motor that drives it fail.
copyman
01-15-2020, 11:52 PM
Take out black Dev unit and see if developer powder is missing (turn mag roller and see if even toner on roller). It may have dumped.
Keep in mind as mentioned on this forum many times, if "any" consumable is over life or bad they can affect "any" other color! Are any other consumables at 0% ? This is a chance you take when you turn off consumable reminders. Still way ahead of the game if this happens once during the life of machine.
blackcat4866
01-16-2020, 12:37 AM
https://www.copytechnet.com/forums/konica-minolta/107925-c284e-cyan-de-toned-but-not-asking-toner.html#post511132
