View Full Version : Miscellaneous Bizhub C224 - SSO SSL
amcargo
01-17-2020, 12:59 PM
Hello, I'm trying to use the SSO with the Bizhub C224 but allways when try to join to the domain get error; we are using the the AD with SSL can be this the problem?? The LDAP can be configure without problem but the SSO allways get server error can't connect.
Thanks for your help and time.
Synthohol
01-17-2020, 01:35 PM
machine old and discontinued.
does not adhere to current security levels required by current servers.
perfect opportunity to upgrade machine to currently supported models.
amcargo
01-17-2020, 02:05 PM
Then is not supported for this model?? I know is not a very new model but is the machine I have :(
An attempt could make it updated to the latest firmware, otherwise it is not supported with the new security protocols.
emujo2
01-17-2020, 06:46 PM
The C224 was probably keyed to server 2008..and yes, current servers would block this all day probably just due to unsupported security protocols..TLS 1.2 ie..But, I have a C468 that I am unable to connect to my 2012 servers due to constraints placed upon the company network. My question is why would you want to join a MFP to your domain?? To take advantage of scanning w/o having to sign in? Or are you trying to print with authentication and windows IDs? Ed
amcargo
01-18-2020, 11:01 AM
The idea is to use SSO to avoid having to configure the driver for each user and create the user by hand
copier tech
01-18-2020, 03:39 PM
There is 'version up' firmware available for the C224 this 'upgrades' your old 4 series to a 4e series this may be a solution for you.
rrrohan
01-18-2020, 05:44 PM
What i normally do when i cant get SSO working is just setup user auth with AD names and no password.
Then install universal driver and in admin section lock the user auth setting so it cant be changed.
Since the users use cards to login at copier they never even know the accounts arent protected by password
Sent from my SM-G955F using Tapatalk
amcargo
01-20-2020, 02:15 PM
I ask to my provider and see if works. Thanks !!
amcargo
01-20-2020, 02:18 PM
How I know which firmware version I have installed ??
ROM Version
MFP Card Version
A5C10Y0-F000-G20-G9(00)
MFP Controller BOOT Program
A5C10Y0-1E00-G00-04(00)
MFP Controller Linux Base
Linux-2.6.26.8-rt16
MFP Controller Kernel Program
A5C10Y0-1C00-G00-61
MFP Controller SubSet
A5C10Y0-1F00-G00-J2(00)
MFP Controller
A5C10Y0-0100-G20-G9(00)
Operation Panel Message Data
A5C10Y0-8100-G00-G0
Fax Board Controller1
Fax Board Controller2
Fax Board Controller3
Fax Board Controller4
Engine Parameter
A5C10Y0-0054-G00-01
Engine BOOT
A5C10Y0-0055-G00-00
Scanner
A5C10Y0-0023-G00-30
Printer
A5C10Y0-0050-G00-26
ADF
A3CF0Y0-0024-G00-12
Finisher
RU
ZU
Panel CPU
A55V0Y0-8900-G60-00
DSC1
DSC2
Loadable Device Driver1
Loadable Device Driver2
SD
Voice Data
Movie Data
A5C10Y0-C000-G00-30
Dictionary Data
OCR Library
Panel Sound Data
A5C10Y0-C200-G00-00
MFP Controller Thread Image Parameter
A5C10Y0-8B00-G00-01
MFP Controller PIC Image Parameter
A5C10Y0-8A00-G00-01
MFP Controller System
A5C10Y0-1000-G20-G9(00)
MFP Controller Print Controller
A5C10Y0-3000-G01-04
MFP Controller Print Controller Font
A5C10Y0-3F00-G01-00
MFP Controller Print Controller Demo Page
A5C10Y0-3E00-G00-81
MFP Controller MIO
A5C10Y0-5000-G00-H4(00)
MFP Controller PIC
A5C10Y0-8200-G00-B1
http://imp1-vlc-konicac224e/wcd/skip.gif (http://imp1-vlc-konicac224e/wcd/a_system_rom.xml#PageEndLink)
emujo2
01-20-2020, 02:23 PM
That SSO functionality also requires special drivers that pull the windows credentials for printing... E
Sorry no special drivers, just enabling SSO under the authentication tab. E
amcargo
01-20-2020, 02:36 PM
I know, this is the driver has the SSO ready and I'm using on Windows 10
44669
tsbservice
01-20-2020, 03:03 PM
ROM Version
MFP Card Version
Linux-2.6.26.8-rt16
A5C10Y0-1C00-G00-61
MFP Controller
A5C10Y0-8100-G00-G0
Engine Parameter
A5C10Y0-0054-G00-01
Engine BOOT
A5C10Y0-0055-G00-00
Scanner
A5C10Y0-0023-G00-30
Printer
A5C10Y0-0050-G00-26
ADF
A3CF0Y0-0024-G00-12
Finisher
RU
ZU
Panel CPU
A55V0Y0-8900-G60-00
DSC1
DSC2
SD
Voice Data
Movie Data
A5C10Y0-C000-G00-30
Dictionary Data
OCR Library
Panel Sound Data
A5C10Y0-C200-G00-00
A5C10Y0-8B00-G00-01
A5C10Y0-8A00-G00-01
A5C10Y0-3000-G01-04
A5C10Y0-3F00-G01-00
A5C10Y0-3E00-G00-81
MFP Controller MIO
MFP Controller PIC
A5C10Y0-8200-G00-B1
You have G20-G9 FW
