View Full Version : Firmware for C364e A5C10Y0-F000-G20-M1
rogernav
01-20-2020, 08:50 PM
Can anyone provide me with this Firmware? A5C10Y0-F000-G20-M1
I tried with the Gxm-m1 and I am getting a Bad Memory error after I did the update.
Needed Urgently.
Phil B.
01-20-2020, 09:42 PM
I tried with the Gxm-m1 and I am getting a Bad Memory error after I did the update. Needed Urgently.Thanks
have you cleared memory?
what exactly HAVE you done?
tsbservice
01-20-2020, 10:08 PM
Never heard about "Bad Memory error" after FW update. Neither that some specific FW will fix it.
What have you done to poor machine?
rogernav
01-21-2020, 01:38 AM
I simply used the USB upgrade after putting the files in the stick.
No other process..
I need the other firmware files so that I can try that I e ...the system was working before the firmware upgrade ...I think the message is it referring to the removed USB stick after the upgrade.
Please send me a link or download for the firmware file requested if you have it?
Hello,
make a donation to the forum, you have a good chance that you will receive the required firmware.
rogernav
01-21-2020, 02:46 PM
I have called Minolta this morning for the Firmware and they say My machine, built in 2013, is out of Contract and they cannot help me.
They have to provide a tech to put the firmware on a USB stick and stick it in the machine as if I cant! Frustrating.
Please does anyone have this Firmware...it has my MFP down for a day already.
I need the G20-M1 Firmware for the BizHub C364e
Thanks.
Synthohol
01-21-2020, 02:49 PM
ck your PMs.
thank you for contributing!!
Synthohol
01-21-2020, 02:55 PM
remember, 4G or smaller flash drive and the contents of the ROOT of the drive is to contain the contents of the subfolder.
on the root you should see APP, BIN, FW, etc folders and the files as well.
SeniorTch
03-20-2020, 10:11 PM
Hi gays you can help me with this firmware I need
haryo
03-21-2020, 12:04 AM
i send you a pm
Hanja
07-16-2020, 09:49 AM
Could someone please assist with latest firmware for Bizhub C554e.
Synthohol
07-16-2020, 12:24 PM
ck your PMs
lithal neveen
02-29-2024, 09:09 AM
hi guys i also need bizhub c364e firmware
copier tech
02-29-2024, 04:37 PM
Happy to help. Please contact us via either website below.
