View Full Version : C258 doesn't show ink levels
edi1907
01-22-2020, 08:48 PM
Hello! I bought katun toners after first original toners. I had problem with katun chip. It didn't work and I changed with old original one and black cartridge shows %100 and all other toners shows same ink level, about %60 and no any change after 2.000 print. How can I fix it?
Phil B.
01-22-2020, 08:49 PM
get rid of the shit toners!
edi1907
01-22-2020, 08:55 PM
You are so right. I bought 2 sets and when I finish these I will back original toners again.
copier tech
01-22-2020, 09:01 PM
He's using 'ink' not toner :cool:
patrickjlc
01-22-2020, 09:24 PM
Buy original toners. Katun are ok if you use on a grocery store or the like.
Sent from my SM-G930V using Tapatalk
tsbservice
01-22-2020, 09:29 PM
Toner level shown issue is last one to consider when using aftermarket toners especially on color bizhub.
No, not saying by my experience just what I've heard.
Phil B.
01-22-2020, 10:01 PM
sure keep running shit toner and it can mess up the unit even more... Dev units are $$$$ .. but hey do what you want.
Bix
01-23-2020, 08:01 AM
Toner levels sometimes get high even with original toners. This is because there is no internal sensor that checks the actual amount of toner left.
You will see that the values will settle from the next replacement with original toner.
copier tech
01-23-2020, 08:23 AM
There is no toner chip on theses bottles genuine or fake.
So to reset the toner count remove the bottle from the machine run it until the machine asks for toner, then fit the used bottle back the counter will reset to full.
edi1907
01-23-2020, 12:39 PM
Thank you so much for answers
tsbservice
01-23-2020, 01:23 PM
From C258 manual.
44705
