View Full Version : Minolta c284 no update firmware
myster
01-23-2020, 05:56 PM
I cannot update the firmware of the machine.
Does not load the update program by the usb, turning on the machine the panel goes black
for a while and ends up turning on normally.
Several pendrives tested and with different firmware versions.
It may be that the machine is missing the MFP Card Version ??
44715
I have tried to update from the internet isw, but the mktar_zeus.bat fails,
I have compressed the folder manually with the command .tar
the machine downloads the file a161fw.tar from the ftp server but it ends up giving error
Does anyone know how the update is done correctly?
thanks
Synthohol
01-23-2020, 06:37 PM
your method is not even remotely close to the correct firmware installation method.
read the service manual.
if you dont have one, become a contributor and ill send it to you.
copier tech
01-23-2020, 10:25 PM
44715
thanks
Have a read
44719
Woxner
01-23-2020, 11:58 PM
just take all the files from the folder and put them on the root. nothing else needs to be on the usb
myster
01-24-2020, 08:43 AM
Have a read
44719
thanks
Those are the steps that I do exactly, I have already updated several
bizhub 4 series machines before.
The problem with this machine is in step 7, the point does not appear in
the corner, only the panel remains black longer to finish starting normally
myster
01-24-2020, 08:46 AM
Thank you
I know that is what I do, but I can't get the firmware update screen to appear
myster
01-24-2020, 09:01 AM
thanks
Maybe the translation from Spanish to English has not been exact,
but I don't understand your answer...
According to the service manual there are only 2 ways to update the firmware of these machines.
1: as indicated by "the Bizhub 4 Series FW update procedure using USB memory stick V2"
by Copier Tech.
2: downloading over a network using the internet ISW, a method that I have not used
before since it is much more difficult than inserting a flash drive into the service port
Synthohol
01-24-2020, 09:14 AM
I have tried to update from the internet isw, but the mktar_zeus.bat fails, irrelevant
I have compressed the folder manually with the command .tar WHY????
the machine downloads the file a161fw.tar from the ftp server but it ends up giving error no tar file needed
Does anyone know how the update is done correctly? follow copier tech's bulletin
none of that is right.
this may be your problem.
does the root of the drive look like step 5?
bushotero
01-24-2020, 10:10 AM
Hi,
Am looking for the firmware for konica minolta c 364 and i cant find them.Kindly assist
rgds
GEORGE
copier tech
01-24-2020, 12:52 PM
Hi,
rgds
GEORGE
Happy to help drop us an email.
Firmware Update - Printer & Copier Firmware (http://www.copierfirmware.co.uk)
