View Full Version : Bizhub C-308 with FS-534 finisher...
Oystercopy
01-24-2020, 03:46 AM
Customer getting frequent jam codes and paper stops/bunches up between exit and the internal finisher. The codes are 3201 and 7217, consistently.
Any help appreciated!
OC
tsbservice
01-24-2020, 06:14 AM
Check operations of Gate switch solenoid (SD3).
blackcat4866
01-24-2020, 12:32 PM
Didn't the 4e series machines do this when the exit section bushing seized up for lack of lubrication? =^..^=
Oystercopy
01-24-2020, 05:02 PM
So, does this series SHARE the same solenoid/exit issues that the -4 series had? I've never seen this happen before in the -8 series, only the -4....??
OC
tech51
01-24-2020, 05:46 PM
Not had exit gate problems but I have had the bushes tighten up just like the 4 range does occasionally.
As soon as I see this code with an embedded finisher it’s the first thing I do, normally cures it.
And just to confirm it’s the exit bushings on the main body, not the finisher exit.
srvctec
01-24-2020, 07:50 PM
OC
I'm confused. The title says FS-534 which is the standard external floor finisher but you mention the internal finisher unless you meant the horizontal unit instead.
Oystercopy
01-24-2020, 09:47 PM
My apologies, it is an internal FS-533 Finisher...
And can someone tell me which exit bushings we're talking about? Are they metal/brass and is that why they dry out and cause drag?
OC
tech51
01-25-2020, 01:08 PM
OC
As I previously said it’s the exit rollers on the main body. They are plastic bushes.
I give them a squirt of ptfe lube and that generally does it.
