View Full Version : Update firmware for bizhub C224e
maximus-1994nr
01-28-2020, 11:43 PM
When I try to update the driver for the printer, I get a message "drivers used by connection printers are not to be updated". Who faced this and how to solve the problem?
Synthohol
01-29-2020, 12:53 AM
talk to their IT person, that has nothing to do with the machine.
is it using simple tcp/ip port or something stupid and amateur?
why is the driver being updated?
what OS?
PS? PCL? XPS?
almost like putting a jigsaw puzzle together upside down.
could use just a bit more info if you want an educated answer.
maximus-1994nr
01-29-2020, 01:01 AM
Sorry, I agree, there is little information.
Used ip port. The old driver version 4.1.0.0 is installed and I'd like to upgrade to the new version 5.3.0.712
OS: Win10 x64
PCL
Synthohol
01-29-2020, 03:30 AM
is it a requirement of the version of firmware on the machine?
is the driver newer than the FW?
is there a printing issue? or any enhancements to the driver?
I'm genuinely curious, for real.
copier tech
01-29-2020, 07:31 AM
Just perform a new install rather than updating the old driver. Once you get this working delete the old one.
If you still get the same message update the firmware & function version.
maximus-1994nr
01-29-2020, 06:55 PM
Yes, the driver is newer than the firmware version.
Sometimes there are problems with printing, especially with printing on an envelope, I decided to update that maybe this will fix our issue.
maximus-1994nr
01-29-2020, 07:03 PM
Thank you so much, everything worked out. How did I not immediately think of this ?!
copier tech
01-29-2020, 07:55 PM
Cool cheers for the update :cool:
tsbservice
01-29-2020, 10:51 PM
Because he is copier tech and you are clearly not ;)
