Bix
01-31-2020, 07:58 AM
Hello,
I will tell you my experience on a Bizhub C284e. Maybe it can be a suggestion for someone.
A week ago the MFP started to restart on its own. It was in standby mode but as soon as the customer tried to print, the C284e was frozen. After turning it off and on again, it kept restarting after less than 2 seconds, so the screen didn't load.
Here's what I tried:
1. I have successfully removed HDD.
2. I have removed all the options without success.
3. I have successfully replaced SSD.
The only one left is MFPB or some power problem. I replaced the MFPB and the C284e started working again.
So I also reassemble the options ... the problem returns! Excluding little by little, I discovered that in the end it was the Dual Scan card of the DF.
Out of personal curiosity, I assemble the previous MFPB again to check if it went without a dual scan card. But oddly enough, it was giving the same problem so something may have gone wrong.
So I put the MFPB back that worked and now it looks like the c284e is working.
I hope this can help. I have wasted an entire day on this printer
