View Full Version : Bizhub C6000/7000 Error code C-281X
tulintron
02-04-2020, 07:08 PM
Why does this line of codes make my hair fall out?
On the C6500 models, it was simple. Just clean the drum's potential sensor and it was resolved.
C6000 / 7000 does not have the sensor and the machine that presents the error has new drums, developers, coronas, transferbelt.
According to manual, the reasoning is:
• Printer control board
(PRCB)
• Developing unit / K
• IDC sensor (IDCS)
• IDC solenoid shutter
(SD3)
But I can guarantee that everything is in excellent condition.
https://www.copytechnet.com/forums/konica-minolta/79667-biz-c6000-l-error-code-c2814.html?79667=#post369545
I followed the advice of lucky13 in this post above, but to no avail.
Any tips that might help?
Thanks.
cricketsi
02-04-2020, 07:17 PM
Might seem like a dumb question, but are the corona's good?
tsbservice
02-04-2020, 07:40 PM
Check the connection of the process carriage drawer connectors for proper connection.
tulintron
02-04-2020, 07:54 PM
new cargo corona and process car mechanism operating perfectly and clean
cricketsi
02-04-2020, 08:00 PM
Ok, you had mentioned the C6000 doesn't have potential sensors, but it does. Still same spot under dev units.
At least, that's what I remember...lol. It's been awhile.
tsbservice
02-04-2020, 08:21 PM
PM send.
wjurls
02-04-2020, 10:01 PM
C-281* Isn't related to the toner density or the TCR sensors. It's due to an error while undergoing gamma correction. Gamma is done by drawing a patch of color and it's density is read off the transfer belt by the IDC sensor. If the IDC sensor is dirty, or the solenoid/shutter isn't working it can result in the C281* code. Problems with the trans belt cleaning, drum, coronas, or a dirty slit glass can also affect it.
Toner density can affect it, but a depleted developer will likely throw a C242* code.
tulintron
02-05-2020, 11:56 AM
Toner density can affect it, but a depleted developer will likely throw a C242* code.Yes, exactly!
However, I notice that the black color is formed with a lighter density than the other colors, that's why my case C-2814.
When Recall is performed within the Process Adjustment, the equipment operates normally for a while, around 600 pages, but soon shows C-2814.
In fact, it happened right after doing a great job with high black coverage. Then a new job with zero black coverage. Started the mistake that won't let me sleep ...
wjurls
02-06-2020, 08:51 PM
Yes, exactly!
You get a visibly light patch even right after loading fresh developer? Is the "dust proof glass" clean?
sadanand
02-07-2020, 04:59 AM
dip sw 11-0 change to 1
Toxic
02-07-2020, 10:10 AM
Some info for what dipsw is would be nice.
tsbservice
02-07-2020, 02:30 PM
PM sent :)
https://www.copytechnet.com/forums/konica-minolta/79667-biz-c6000-l-error-code-c2814.html?79667=#post373550
sadanand
02-10-2020, 05:29 AM
by changing dip sw 11-0 from 0 to 1 you can disable error code then find out which colour has problem max times problem is with black or cyan
