View Full Version : Konica 226
Hi everyone my konica 226 show code c 2558
Any suggestions
Thinks
Phil B.
02-04-2020, 08:17 PM
Any suggestions
Thinks
get a service manual
copyman
02-05-2020, 01:25 PM
Never heard of a 226 but that code with Kon/Min means something wrong with toner or developer. You should be able to find a service manual online that will explain excatly what code is and how to fix it.
Another option would be to make a small donation ($5 or $10) to this website and myself or someone will send you the manual.
REGSIS
02-06-2020, 09:44 AM
Any suggestions
Thinks
C2558 high TCR value.
Open original cover/ADF and make 10ish copies.
Paper should be full black. That will lower TCR ratio. Continue to work normally. If error reapears than repeat the procedure again.
Depending of TCR value you may need to repeat it more or less times.
If this doesn't help call the service to replace developer.
Depending on machine's life (counter) drum or IUassy may need to be replaced also.
Toxic
02-07-2020, 09:06 PM
I think he use non OEM toner and that cause this problem.
It's a common issue on this model, although the genuine toner and parts are being used.
You can adjust the TCR value first time, replace developer if it displays next time.
