View Full Version : C4050i with C - 5604
Roger67
02-05-2020, 11:54 AM
Hello,
i have a brand new Bizhub 4050i who comes with a C - 5604 right after startup.
There is no discription in the Manual about that .
Any ideas ?
Roger
tsbservice
02-05-2020, 12:23 PM
Hello,
Any ideas ?
Roger
Yes indeed I also can't find info about it.
Try to run full self-diagnostics and start from there.
Roger67
02-05-2020, 12:43 PM
Hello,
it seem that the problem comes from the Mass storage Board.
Its not possible to install it or even deactivate it.
I just ordered a new one.
Roger
tsbservice
02-05-2020, 12:55 PM
Try FW first.
Roger67
02-18-2020, 08:37 AM
Hi Folks,
after spending a couple of Hours i still have the C 5604.
I changed
PWB
Storage Board
BASEBOARD
FW Version 79 is installed.
The Code comes right after startup even bevor any Initialisation has started.
Realy strange
Roger
Bix
02-18-2020, 09:33 AM
It could be some pinched wiring if you replaced everything. Have you tried contacting KM?
What does self-diagnosis tell you?
Roger67
02-18-2020, 10:21 AM
Hello,
no i dont have an Direct Contact to KM.
For execute a CALL i need to go to an other Dep in our Company.
Pinched Wiring is possible,but its even more difficult to find IT !
The Self-Diagnosis tells me that everything is OK ( ? )
Cheers
Roger
Bix
02-18-2020, 10:36 AM
Another attemp
have you tried a trouble reset? Press the yellow button on the back of the display panel when you turn on the MFP.
Roger67
02-18-2020, 11:40 AM
Another attemp
Yes,i i have don this several times.
kurtjo
11-14-2022, 01:20 PM
Hi.
Did you find a solution to the problem?
BR
Kurt
and
11-14-2022, 03:12 PM
Hi.
BR
Kurt
Error Code C-5604
C-5604 shows on a problem that is called "PH configuration error".
The problem is that the Print Head information that the Engine has and the PH information that is actually set, do not match.
Boards that belong to the system are not installed.
Please return the original boards back to the system
kurtjo
11-14-2022, 08:31 PM
Error Code C-5604
Thanks, but did ‘t you have the problem before changing any boards?
And is it possible to change the print head info?
/Kurt
