View Full Version : Error Code Konica Minolta accurio print C2060L error
bouba411
02-07-2020, 09:46 PM
Hi
Need help please. My Konica Minolta C2060L display "ready to print" and "controller unconnected" then, not allowing to print a all.
Any advices?
Thanks.
Synthohol
02-07-2020, 09:57 PM
web into the controller and see whats going on.
bouba411
02-07-2020, 10:20 PM
Since "there is no controller" we Cannot access to the machine other than by using its own display.
Synthohol
02-07-2020, 11:35 PM
through the network.
same IP you print to.
in a browser or in some cases RDC.
blackcat4866
02-08-2020, 02:06 AM
Is the controller ON and at "00"?
bouba411
02-08-2020, 05:55 AM
It is an onboard controller, (ic-603), when the machine is ON the controller is ON.
orestesp
02-08-2020, 07:04 PM
From what blackcat4866 said, this print controller has 2 seven segment LED displays side by side somewhere on the controller (usually found on the back of the controller or on the motherboard) that indicate its status, if it's not showing "00" after a few seconds since pressing its power button, then something is wrong with it.
I am unfamiliar with this print controller, so I can't help you locate them...
bouba411
02-09-2020, 10:07 AM
Dear sir.
Konica minolta accurio press c2060L come completely closed. You put ON the machine, the controller automatically is working. You don't even have to think about it. It's an inside part of the machine. There is no led to check no button to push... Untill I got the error "controller unconnected" or "controlleur débranché".
I think you all are thinking about some kind of fiery standing outside the machine. NO it's not like that.
I'm pretty sure it's just a matter of touching screen to reconnect it. Because all test pass and the machine is even able at this time to make copy and scanning. Only the printing, that is vitale for me, is not working because of the message "controller unconnected".
44849
orestesp
02-09-2020, 11:26 AM
Dear sir.
44849
Try accessing the controller following what the manuals says: Accessing PageScope Web Connection (https://manuals.konicaminolta.eu/AccurioPress-C2070-C2070P-C2060/EN/contents/id02-_102707433.html)
konicavod
02-09-2020, 11:58 AM
Any advices?
What did you do with the device before you received the message?
Perhaps you were flashing the firmware?
also take a full screen photo.
tsbservice
02-09-2020, 01:46 PM
Check that the following DIPSW is ON (1).
40-7: ON(1)
bouba411
02-09-2020, 07:40 PM
4485144852
bouba411
02-09-2020, 08:01 PM
4485344854
bouba411
02-10-2020, 10:14 AM
40-7: ON(1)
Hello,
Putting 40-7:ON lead to error code c-D0D1
konicavod
02-10-2020, 02:55 PM
bouba411
02-10-2020, 03:06 PM
I don't know how to flash a firmware.
Is there a solution ?
Do I have to prepare myself for buying a new printer ?
Would you please help me get out of all this ?
konicavod
02-10-2020, 03:15 PM
konicavod
02-10-2020, 04:47 PM
10-1: ON(1)
bouba411
02-10-2020, 05:43 PM
10-1: ON(1)
I put in ON.
Now I have this error : d0d1 (3)
tsbservice
02-10-2020, 05:51 PM
bouba, stop crying like baby and tell us what have you done to this machine. If you want it back we need much more than nonsense you posted.
bouba411
02-12-2020, 06:00 AM
Played a lot with DISPW trying to erase error c-2801.
konicavod
02-12-2020, 08:43 AM
dipsw is not for playing. return them back.
bouba411
02-13-2020, 06:01 AM
How ?
raplma
02-13-2020, 08:37 AM
Permit me to state what everyone else is thinking...
and I say this as someone who is ultimately an end user who does his own maintenance, but over the years has spent an obsessive amount of time reading the theory manuals, field service manuals, parts manuals, for each machine we've had...
...know when you're out of your depth, bite the bullet in terms of cost and get an experienced tech to come and have a look.
You're running a minimal setup with the basic onboard fiery, very few of us come across your fiery combinations - I didn't even know these existed until your post - as most production machines are installed into an environment that requires a production quality fiery and features. If the internal fiery isn't connecting that's definitely a job for someone who knows these rare fiery setups.
Good luck
bouba411
02-15-2020, 05:59 AM
Thank you all. found solution visiting russian forums.
Problem fixed with one line of text, using google translator and yandex the russian browser.
Thank you all.
