View Full Version : Bizhub C368 Bootup Screen
tulintron
02-11-2020, 06:56 PM
Good afternoon.
I'm on a C368 bizhub, but the option is disabled.
Is there any dipsw or some configuration for the option to be unavailable on the panel?
Nothing in the configuration manual, just installation
arahael
02-11-2020, 07:06 PM
Try firmware. Then emmc board faulty
tsbservice
02-11-2020, 07:10 PM
Are you positive that in System 2 - Import config data - BootUp screen tab is missing?
emujo2
02-11-2020, 07:51 PM
this may be a result of USB connection settings being disabled, or enhanced securty set to ON. E
tulintron
02-11-2020, 08:37 PM
current firmware G00-K7
enhanced security disable
USB enable
copier tech
02-11-2020, 08:55 PM
Good afternoon.
You cant disable the boot up logo by default is the KM logo or you can change it to your own.
System 2>import config data.
tulintron
02-13-2020, 12:21 PM
Good morning guys.
The solution for my case was to format the HDD in physical, disable HDD, base firmware until the most recent, format SSD, enable HDD, format logic, and finally the option I needed appeared.
Thanks.
