Slammers
02-12-2020, 04:45 PM
Hello, looking for some advice concerning a C258 that is less than a year old. 53k clicks, low volume machine.
I was called out to site for an unrelated issue to do with envelope mis feeds, appeared to be a logic error with jam at fuser.
First thing I do is print a count sheet before cracking on with my work, the result I got from this was concerning. I have attached a scan of the front and back side of the document the machine printed.
NOTE these are NOT the result of a COPY, this came out of the machine from an internal report print.
I re printed the report and it came out OK, no weird zoom, shading or banding.
Information:
Firmware K7 - Upped to X4 on site to resolve the original issue, anomaly observed while on K7
Self Diagnostics results: All Passed
State confirmation: All TCR levels within expected levels
TCR adjusts: Deafult - not touched
Image Adjusts: Default - not touched
K Dev: Visually inspected, mag roller perfect, unit still looks brand new. Contacts all clean. Halftone test prints perfect.
K Drum: Visually inspected, charge roller not marked, drum surface OK. Contatcs all clean. Halftone test prints perfect.
Service call history: No codes. No skew errors on maintenance screen (Initially suspected PH)
Have escalated to support but was wondering if anyone else has experienced this issue and what was done to resolve. I suspect an issue with the MFPB but want to dig more before pulling the trigger on a warranty claim.
It should be noted that I couldn't replicate the anomaly observed and the customer has had no problems with image quality. Just want to get some insight before this rears its head in x months time as its pretty much guaranteed to be out of warranty by then.
Thanks for your time.
4489344894
Information:
4489344894
