View Full Version : BIZHUB C550 - Problem c-3822
bennie2225
10-28-2008, 11:47 AM
Hey guys
Im running a bizhub C550 and have had know problems with it what so ever. I now have an error saying that its a c- 3822 problem.
any ideas?
pepper38_cnd
10-28-2008, 12:21 PM
That error is abnormally low fuser temp. Try Trouble reset if problem persist call a qualified tech. Make sure media setting match the stock you are using ( heavy stock run at a normal setting can suck the heat out of the fuser).
See attachment for reseting procedure
WaveyDavey
10-28-2008, 03:23 PM
this is a common problem on this model we have seen it loads of times with various reasons. ranging from faulty connecters, worn bushings in the fuser unit, faulty induction board and even a replacement machine under warranty.
follow the reset once but if it persists then get a qualified tech to look at it as you may cause more damage.
kld04g
11-26-2008, 03:01 PM
The bizhub C550 in our office was experiencing this problem this morning when I found this site. I just wan to say thanks to everyone for posting up this information. The trouble reset solution worked perfectly!
Big thanks,
Kevin Dompig
IT Specialist
Home Page — Telstra International (http://www.telstra-usa.com)
bizhub550
05-05-2009, 08:22 AM
Thanks a lot for the manual how to trouble reset the printer, it worked fine for us and I'm sure it saved us lots of money! :D
nantech
10-01-2009, 04:47 PM
Thanks for the information. I was able to clear the error using Trouble reset. So far, so good.
tech51
10-01-2009, 06:19 PM
There is firmware to cure this, its version GC4-22. It also fixes the random P14 codes that appear. I`ve used it on a number of problem machines with 100% success.:)
t_abida
02-08-2010, 07:11 AM
thanks a lot guys this was really helpfull
SCTROJAN
12-13-2010, 05:18 PM
THANKS pepper38_cnd !!!! :) Your reset solution worked perfectly for a bizhubC650 as well!!!!
servicepro
05-18-2018, 05:00 PM
This helped us temporarily too.. BUT we're not supposed to reset it multiple times :( ... and I have already a couple of times (2 days) ... waiting on technician
