View Full Version : MAC reporting image units expired
copier tech
03-06-2020, 01:42 PM
Maybe a silly post but here goes.
We have a C308 that all image units are @100% print quality is fine & no message on the screen.
However the MAC users get a message that the image units need to be replaced, Windows users don’t!
Is there a way to “turn off” this warning for the mac users, SNMP maybe?
(Please don’t suggest replacing the IU’s lol)
Bix
03-06-2020, 01:47 PM
Of course, disable SNMP. The only problem is if you use monitoring software, it may not work
Bix
03-06-2020, 01:52 PM
Check this: How to supress PM Part messages at end unser computers (http://www.copytechnet.com/forums/konica-minolta/132723-how-supress-pm-part-messages-end-unser-computers.html)
jhalfhide
03-06-2020, 02:21 PM
Alternatively, instead of disabling SNMP why not change the community name and change accordingly in your monitoring software. That way nothing but the software will use it
Sent from my LYA-L09 using Tapatalk
tsbservice
03-06-2020, 04:14 PM
Switch 230 deals with MIB (Management Information Base), I believe it will stop warnings for both MAC and Windows users.
copier tech
03-06-2020, 09:07 PM
Thanks, so SW 230 what HEX do I set?
tsbservice
03-06-2020, 09:20 PM
Set it to 'Not display'.
emujo2
03-06-2020, 09:36 PM
I would advise against any changes to the SNMP string settings, or disabling the protocol. You may solve you MAC issues, but you will now have worse PC issues. E
Bix
03-09-2020, 02:58 PM
The best solution is to disable it from the driver. So it also solves problems of any "offline printer" reports. On Windows it's a very simple flag, on MAC I don't know.
jhalfhide
03-09-2020, 03:44 PM
I would advise against any changes to the SNMP string settings, or disabling the protocol. You may solve you MAC issues, but you will now have worse PC issues. EYou can update your changes driver side too. It's actually best practice in terms of network security, to not run standard SNMP trap names
