Sam Tofu
03-06-2020, 07:52 PM
Initially just a change Drum'Image unit warning. However, when entered Utility/Counter THEN on right side with meter/Check detail it was sort of faded out and non responsive. Poking around here found all the old posts re 350 drum etc. Drum being OK and DV being jet black and solid, I was simply going to check and if necessary change soft switch settings.
Going back today to see if could get into tech mode, the C2557 had now come on.
SO ? is is there something I may be doing trying to get into screen to enter the normal Stop 00 .....
If can reset and even if have to change drum and DV (Which are totally good) customer is willing. But if additional electronic issues then the machine is destined fro recycle.
Any ideas re why screen on right of Ultility /counter won't respond other than board issue GREATLY aprreciated
TIA ;)
TIA ;)
