View Full Version : Error Code C-3B02 Bizhub C652
Khumz
03-07-2020, 12:00 PM
Which part to look into first?. Definitely cant change all listed parts at once according to error code definitions.
tsbservice
03-07-2020, 12:22 PM
Did you try using Trouble Reset?
Khumz
03-07-2020, 12:28 PM
Trouble reset is not working. Same problem pursists.
tsbservice
03-07-2020, 12:36 PM
Replace the IHPU. Next replace the Coil.
Khumz
03-07-2020, 12:48 PM
It sounds so stupid to say i cant access the IHPU. I stripped the machine from the back, removed Main PSU but cant see the IHPU. I guess i was too tied.
tsbservice
03-07-2020, 01:29 PM
Eghhh, you don't have a manual:confused: How can you service machines that way, imo it is really stupid and time consuming.
Last hint before I'm done with this. IHPU is behind covers, front-upper-right side. Remove 3 plastic covers and some metal shieldings to get IHPU.
