View Full Version : C250 Error Code C-2253
Stephanyie
10-29-2008, 06:54 PM
I have a Bizhub C250 that is displaying error code C-2253 "Malfunction Detected" It was working in the morning and then this code came up, don't know what happened...
alexxcopier
10-29-2008, 07:49 PM
C2253 Color PC Drum Motor's failure to
turn
The Motor Lock signal remains HIGH for a predetermined
continuous period of time while the
Motor is turning.
take Imaging units out and take a look for something wrong try to rotate drums
Stephanyie
10-29-2008, 08:25 PM
I looked at the imaging units, they look fine to me, but I don't really know what I am looking for... and what are the drums? How to I rotate them?
Stephanyie
10-29-2008, 10:00 PM
I also found that if I open the front of it and then close it, it resets for a second, it sounds normal for a second but then it clicks and it sounds like a fan goes on from the side of it by the bypass tray area and then the message comes back. Hope this helps you help me
RockETop
10-30-2008, 12:28 PM
"Call the Man..." - Andy Taylor
JustManuals
10-30-2008, 05:08 PM
Another one who didn't read the header:
An online community for copier-printer and fax technicians
Call one.
Stephanyie
10-30-2008, 05:50 PM
Sometimes you find help in odd places, thanks for the attitude instead of assistance, it is really productive I hope you feel awesome about yourself. And instead of calling a tech, I thought I would try this first, but I see how it is, you are a jerk... thanks alexxcopier for at least trying
alexxcopier
10-30-2008, 07:14 PM
drums are green cylinders they have to be turned only in one direction but it is hard to explain here, so take them out /the fourth/ and try one by one to rotate maybe one of them is stuck or something i don't know
better way is to observe and if you find something wrong go ahead, but if you did't find call a tech
wish you luck
Stephanyie
10-31-2008, 08:00 PM
Thank you- tech person came out today and found that the board and motor both were bad and needed to be replaced. About $1700 in parts alone, at least $500 in labor. Thanks so much for your assistance.
ni311
11-03-2008, 05:28 PM
too bad you're not a tech, you could win $2200 :D
RockETop
11-04-2008, 12:43 AM
Gee. We were right. And no thank you.....
redime
11-09-2008, 02:51 PM
This is why you also dont buy a copier without a service contract :D
Especially something with 4 image units and a transfer belt :cool:
