View Full Version : C454e C6104
jwai
03-09-2020, 10:42 AM
Hello,
I have one C454e that display C6104.
I disassembly and check the driving of CIS cleaning unit, it rotate several turns , the cleaning roller move when I manually turn the motor.
The home sensor get bad? or other else?
Genotrom
03-09-2020, 10:58 AM
Hi, start a load check, don't do it manually.
I think it's 60 - 81 If you hear noise, stop and locate the stuck paperclip. If so, make sure that the sensor is not dirty and that the cleaning roller belt has not jumped.
blackcat4866
03-09-2020, 11:56 PM
Yeah, you can get the code if it's out of time. =^..^=
jwai
03-10-2020, 05:25 PM
thank you all.
as i checked that cleaning roller mounting unit, i found the back side lock lever cracked.
so it slightly uneven width on the entrance of paper path.
this condition will cause code?
allan
03-10-2020, 06:33 PM
I would guess that could be the reason the belt would have jumped.
tsbservice
03-10-2020, 08:22 PM
Check for cleaning motor broken mounts. Believe it or not there is FW update dealing with this issue. Not after it happened anyway.
jwai
03-11-2020, 05:31 PM
Thank you for your prompt.
I'm waiting for the jam release lock lever, I will check them also after the replacement.
blazebusiness
03-18-2020, 07:32 PM
thank you all.
That condition will certainly throw the code because when the jam release door is not closed properly the brush rotation movement is "locked" until it is closed properly.
Replacing the back side lock lever should solve your issue.
