View Full Version : Dead Machine C70Hc Não sai da tela inicial
Destak Produções
03-16-2020, 05:39 PM
45270Boa Tarde.
Tenho uma maquina da Konica Minolta Bizhub Press C70hc.
No ultimo sábado 14/03/2020 liguei ela e fiz um total de 500 impressões depois desliguei a maquina normal chegou hoje segunda feira 16/03/2020 cheguei pela manhã e liguei ela só que ela não sai da tela inicial escrito ( Please Wait, System Starting) e o botão do Power Save fica piscando a maquina não faz nem o barulho normal dela quando linda e nem sai da tela de inicialização.
Alguém sabe me dizer oque pode ser?
Phil B.
03-16-2020, 06:13 PM
45270Boa Tarde.
in English? :mad:
Destak Produções
03-16-2020, 06:15 PM
in English? :mad:
I have a Konica Minolta Bizhub Press C70hc machine.
Last Saturday 03/14/2020 I turned it on and made a total of 500 impressions then I turned off the normal machine arrived today Monday 03/16/2020 I arrived in the morning and turned it on only that it does not leave the initial screen written (Please Wait, System Starting) and the Power Save button is flashing the machine does not even make its normal noise when beautiful and does not even leave the startup screen.
Can anyone tell me what it can be?
Phil B.
03-16-2020, 06:19 PM
did you read the service manual on this problem?
or are you just an end user?
Destak Produções
03-16-2020, 06:22 PM
[CITAÇÃO = Phil B.; 1360847] você leu o manual de serviço sobre este problema?
ou você é apenas um usuário final? [/ QUOTE]
I'm just an end user I know a little of this machine but this error had never happened to me I tried everything to turn it on without the controller turning on with the fusion out and even then it stays on the home screen and it doesn't come
tsbservice
03-16-2020, 06:35 PM
Existing OACB has become corrupt. You may get lucky flashing OACB with the latest firmware or may need a new OACB.
Either ways it's repair beyond enduser potentiality. Better to find certified KM tech.
Destak Produções
03-16-2020, 06:38 PM
[QUOTE = tsbservice; 1360889] OACB existente ficou corrompido. Você pode ter sorte com o OACB piscando com o firmware mais recente ou pode precisar de um novo OACB.
De qualquer maneira, ele é reparado além da potencialidade do usuário final. Melhor encontrar a tecnologia certificada de KM. [/ QUOTE]
So in case the initialization file is corrupted?
