View Full Version : Ecosys P7240cdn -Three Tier setup
Have tried to set the Color three tier with the Prescribe commands: I ran each line as a separate Print command.
!R! KCFG "TCCM",1;exit;
!R! KCFG "STCT",1,50;EXIT;
!R! KCFG "STCT",2,100;exit;
But still does not show up.
Kuby,
I think the bulletin may be slightly incorrect; try the following commands with single quote '. This was written as one command to turn tiered on, set values, and print status pages.
!R! KCFG'TCCM',1;
KCFG'STCT',1,20;
KCFG'STCT',2,50;
stat;
stat1;
EXIT;
Thanks, fixed it. The stupid Windows 10 drivers were messing it up. Have to go it and make sure that Windows 10 does not automatically install WSD drivers for Kyocera even though you install it VIA Tcp/Ip.
taskalfaman
03-20-2020, 09:29 PM
you just putted different levels as asked
asked
O-2
2-5
+5
suggested
0-5
5-10
+10
this van have a huge inpact if the customer is charged with toner coverage.
