View Full Version : Biz i series troubleshooting guide
copyman
03-22-2020, 03:15 PM
Hope this helps
allan
03-22-2020, 10:28 PM
Great finally they noticed the fix for the paper feed units. Will probably get more than 150K out of the rollers.
Even it this means a different pickup, feed and separation roller.
Sure this will work on older models too.
copier tech
03-23-2020, 09:16 AM
Hope this helps
Thanks for sharing!
avecosat
03-23-2020, 10:01 AM
Thanks for the information
copyman
03-23-2020, 01:25 PM
Yes, finally some good improvements. Wonder how much these new rollers are going to cost, $20 - $30 each? Lol
Speaking of rollers, I've had good results with using aftermarket from Copylite & Katun, Use the ribbed & red feed from copylite and the katun red feed for sep. The copylite red has same tacky feel as OEM the katun isn't as tacky so better for sep. Been getting at least 100k with this combination. I found if you use same red (oem or generic) for feed & sep they wear in less than 50k
rrrohan
03-25-2020, 05:25 AM
i thought we always had different rollers. to be honest i only use the a00j563600 red ones but do recall back in the day use to be asked to use the blue ones for longer life.
copyman
03-25-2020, 01:31 PM
The 5636 rollers wear faster when used as feed and sep. Doesn't matter with pick up because not rubbing against another roller. And like I posted I have been using the ribbed for P/U instead of the red with much better results!
Hope this helps
Thank you
marvin_PL
03-25-2020, 07:57 PM
Any part number of new rollers?
copyman
03-25-2020, 08:57 PM
Ribbed P/U: A64J564201
New style Feed: A64J564101
New style Sep: AA2J560000
konicatoshiba
10-24-2023, 11:40 PM
Hope this helps
MANY THANKS!
