View Full Version : Samsung 6332 dn smtp send error
Yannii2175
03-26-2020, 11:43 PM
First i had a connection error and got past that. Now it always displays smtp send error, ive tried multiple smtp, pop 3 settings with user authentication and none have worked so far for gmail smtp anyhelp would be great..
check if customer changed password and also check less secure apps is turned on
Yannii2175
03-27-2020, 12:01 AM
[QUOTE=bsm2;1400037]check if customer changed password and also check less secure apps
Tried both still get smtp send error
put 8.8.8.8 as 2nd dns
was it working and stop or just setting it up
scanmc
03-27-2020, 01:26 AM
If I recall the SCX6332 is a pretty old machine and may not be able to support gmail
Yannii2175
03-27-2020, 01:32 AM
Kk i was just settin it uo should i use a different smtp provider?
Yannii2175
03-27-2020, 01:40 AM
does your machine support ssl or tls?
Gmail SMTP server address: smtp.gmail.com
Gmail SMTP username: Your Gmail address (for example, example@gmail.com)
Gmail SMTP password: Your Gmail password
Gmail SMTP port (TLS): 587
Gmail SMTP port (SSL): 465
Gmail SMTP TLS/SSL (https://www.lifewire.com/tls-vs-ssl-4156306) required: on
ully qualified domain name of SMTP service
aspmx.l.google.com
Configuration options
Port 25
TLS not required
Dynamic IPs allowed
Can only send to Gmail or G Suite users
Authentication requirements
None
Yannii2175
03-27-2020, 05:24 AM
aspmx.l.google.com
Port 25
TLS not required
Dynamic IPs allowed
None
It doesnt show any tls or ssl options to confige at all dont think that supported in this machine
slimslob
03-28-2020, 05:41 PM
If the SCX6332 is too old to support TLS which is required now by most email providers, your only option is to use aspmx.l.google.com as the SMTP server. You will be limited sending messages to only Gmail or G Suite users. You may have to configure the authentication email address to allow "Less Secure Apps".
Send email from a printer, scanner, or app - G Suite Admin Help (https://support.google.com/a/answer/176600?hl=en)
Your other option is to install and configure a relay service such as stunnel on a computer.
