View Full Version : Error Code C-3452 on KM- C450
cpress
10-31-2008, 03:27 PM
I just replaced the fuser unit and this code came up . How to i fix this code
TIA
David
RockETop
11-01-2008, 01:10 PM
Search is your friend.....
http://www.copytechnet.com/forums/konica-minolta/10478-bizhub-c351-error-c-3452-a.html?
http://www.copytechnet.com/forums/konica-minolta/5487-minolta-bizhub-c450.html
copy shop
11-01-2008, 03:04 PM
Different malfunction resetting procedures apply depending on the rank of the trouble code.
* List of Malfunction Resetting Procedures
Trouble Code Rank Resetting Procedures
Rank A • Trouble Reset
Rank B • Opening/Closing the Dront Door
Rank C • Turning Main Power Switch OFF/ON
For details of Trouble Reset, see Adjustment/Setting below
Functions • If the all troubles occur and the status would not be cleared by turning Main Power Switch OFF and ON again, or opening and closing the front door, clear the status of the machine.
Use • To be used when the status would not be cleared by turning power OFF and ON again, or opening and closing the front door in case of a trouble.
Setting / Procedure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while hoding down the Utility/Counter key more than 10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed below and then it has been reset.
If ok is not there , it will show a different code....
IF it says OK, you should be good to go.
5. Just Turn off the Main Power Switch and turn it on again more than 10 seconds after, and make sure that the machine properly starts.
Hope this helps
Tammy
