View Full Version : Error Code Bizhub c558- error 2156
tonerspot
04-09-2020, 09:56 AM
One year mashine arround 50k start to pop up code every morning,clear with front door not possible, only when take out belt unit and manual rotating gear can clear code. Cluch on fuser drive is changed, same error. KM told about firmware, but i think for belt assy.I have belt for c258 , can i use it, to ignore belt assy. Tnx
GIUBOSS
04-09-2020, 11:45 AM
Compatible models
Konica Minolta bizhub C224
Konica Minolta bizhub C224e
Konica Minolta bizhub C258
Konica Minolta bizhub C284
Konica Minolta bizhub C284e
Konica Minolta bizhub C308
Konica Minolta bizhub C364
Konica Minolta bizhub C364e
Konica Minolta bizhub C368
Konica Minolta bizhub C454
Konica Minolta bizhub C454e
Konica Minolta bizhub C554
Konica Minolta bizhub C554e
tsbservice
04-09-2020, 12:25 PM
I have one with that error, not intermittent though. Replacing belt fixed it, and I repaired their TBU later with spare parts from another broken TBU.
As for TBU from C258 I'm not sure it will fit into yours C558, they may be same but are listed as different.
ivovb
04-09-2020, 12:37 PM
You need X4 firmware to get rid of the problem.
BR
tsbservice
04-09-2020, 03:06 PM
BR
Now I checked and confirm. Firstly update FW to G00-X4.
tonerspot
04-09-2020, 04:50 PM
I was updated today, will see what next.Thanks for all.
tsbservice
04-09-2020, 05:30 PM
Please don't forget to update your post with final resolution.
Good luck
Woxner
04-10-2020, 01:36 AM
here is a bulletin for the belt 45429
tonerspot
04-10-2020, 01:52 PM
Same code again, i will order new belt.:(
