View Full Version : jams
antone
04-27-2020, 12:17 AM
Tray 1 only shew copies..replacement of complete feed unit! 2,3, 4 trays works fine.Sometimes you can get good copies!
Sent from my SM-N950U using Tapatalk
allan
04-27-2020, 12:26 AM
Machine model and jam code?
Set loop adjust to max?
Indicate more information also on counters please...
copyman
04-27-2020, 07:37 PM
Antone, there are some great techs here but don't know of any mind readers??? If I could read your mind for the model number we would definitely try and help. Actually if I could read minds I would be at the casino making $$$:cool:
I'm sure it was an oversight, post the model # if you still need help.
tsbservice
04-27-2020, 08:18 PM
As it has 4 trays my educated guess would be it's from bizhub A3 model line.
If machine has high mileage check registration roller bushings for wear and tear. If new install I would suspect some chassis bending but really that is some sci-fi chanting...
antone
04-28-2020, 01:41 AM
sorry Biz 458 no jams just skewed copies only tray 1
tsbservice
04-28-2020, 07:40 AM
Swap paper trays for test. There is also additional mylar added to the rear end of existing one (p/n: 4348311712) to prevent paper skew and dog ears.
allan
04-28-2020, 11:04 AM
What comes to mind would be the driven rollers on the first relay roller not having even pressure on both rollers for some reason.
It takes some doing but you can jig the machine to run with the door open to see if it come out skew from the feeder.
kenpio
04-28-2020, 01:19 PM
What solved this problem in the 4 models, was to take out the registration roller unit and to clean all four bushings of those rollers. Something held them up and only tray one would skew. Hope this helps.
KEN
