View Full Version : paper wrinkles in konica minolta c452
jemmanuil
04-29-2020, 06:54 AM
When i print through the bypass no paper wrinkle occurs, but when i print from the three paper trays (either a4 size or a3 size) a little bit of wrinkle appears on the sheets of paper. I tried interchanging the paper in the trays but the problem persists. Can you help?
Leyahné
04-29-2020, 08:59 AM
Hi, how many copies has the machine done?
Sent from my SM-N960F using Tapatalk
allan
04-29-2020, 09:11 AM
Possible wear on the exit drive gears?
EarthKmTech
04-30-2020, 10:28 PM
these crusty old machines used to do that when page volumes got high and transport rollers diameters shrunk but it was always on A3. C451 series was worse for it. You can play with tray loop settings which helped me if i remember correctly. This is assuming no obvious damage such as snapped off fusing loop actuator.
