View Full Version : Bizhub c224
Hello. Can anyone please send me firmware or what is needed to completely wipe and restore a c224 machine? I know that firmware is not available online and that i should get a tech. However, this is at a remote location, so that is not an option. I have a few issues with the machine, like changing admin password, etc. If i could get firmware for c454e as well, taht would be great. Thanks in advance.
allan
05-01-2020, 10:20 PM
Change admin password in service mode if that is the only real issue.
There are very little reason to ever clear the entire machine unless board changes were made or the machine was locked on purpose and someone else is trying to unlock it.
For resale there are procedures to be done that does not involve firmware.
There are very little reason to ever clear the entire machine unless board changes were made or the machine was locked on purpose and some one else is trying to unlock it.
There are many other issues actually. Faxes are sent as emails. Many settings are missing. The fax module is in place.
How can i completely reset it to factory settings?
allan
05-01-2020, 10:38 PM
Service mode > System1 > initialization
The instructions to set/unset forwarding a fax to an email address and to set it to print would be under admin settings.
Ok, will do. This will basically delete ALL data and settings from the machine, correct?
tsbservice
05-01-2020, 10:41 PM
Use the power...just kidding. Get the service manual.
Ok read the manual, i get it. Last question, what can possibly go wrong?
allan
05-01-2020, 11:02 PM
Fix your admin password issue first.
You will loose the network configuration settings, and could possibly need to set the HDD again.
Other than that not much.
Phil B.
05-01-2020, 11:17 PM
Other than that not much.+2 on this
copier tech
05-01-2020, 11:37 PM
Happy to help drop us an email
www.copierfirmware.co.uk (http://www.copierfirmware.co.uk/)
Admin pass is set to default which is ok but setting is missing in http.
How do I set the HDD? Through service menu?
Decided not to clear data. Will start a new thread regarding a fax issue.
