View Full Version : Miscellaneous Develop Ineo+ 224 - Invalid External Memory while updating Firmware
mearmi
05-02-2020, 05:10 AM
Develop Ineo+ 224 -
Getting Error - This is Invalid External Memory while updating Firmware.
For other machines same USB works fine. Even tried another USB but same error.
Please advise.
Thanks and Kind Regards,
mascan42
05-02-2020, 11:35 PM
Was anything done before updating like replacing boards or HDD? Also, make sure you're formatting the USB drive before copying firmware.
Synthohol
05-03-2020, 01:46 AM
id try backing up the addressbook and do a full data clear.
reenable the HDD and load movie data.
it usually takes FW after that.
/.02
tsbservice
05-03-2020, 12:53 PM
Agree with above replies. If pre-history depends on what is it. If nothing was done prior I will just follow what Synthohol suggested. Side note, make sure you've correct FW for the model.
mearmi
05-08-2020, 06:33 AM
/.02
Can I have FW and Movie Data
Many Thanks
mearmi
05-08-2020, 06:34 AM
Nothing replaced. Yes formatted the usb .
mearmi
05-09-2020, 07:14 AM
/.02
Can I have the latest firmware and Movie Data
Thanks a lot
Synthohol
05-09-2020, 04:15 PM
is the konica equivalent a 224e? there was no 224 non e.
SMARTENGCENTER
05-09-2020, 04:17 PM
Dear Friend.
Can you share the display picture of the copier what exactly you facing the problem.
Synthohol
05-09-2020, 04:20 PM
pm sent :)
Konica C224 is Develop +224
In my Develop cross ref shows Konica C224e develop +224e
mearmi
05-21-2020, 08:54 AM
You are Right. It is C224 not C224e
Anyone has latest firmware and movie file for C224?
Many thanks.
tsbservice
05-21-2020, 09:21 AM
Check your PM in 5 min.
Simza
05-21-2020, 10:51 AM
Hi Friend,
i have face this problem also manytime,
you have to check.
-formatting the USB (FAT32)
-make shure that you have e-version data or normal 4serial FW-data
-Dont use Kingstone....USB. U need simple noname USB, because minolta dont check many USBs.
Best of luck
Stay Safe
mearmi
05-22-2020, 07:46 AM
pm sent :)
Thanks a lot everyone.
Re seated SSD , Changed the RAM. Updated the firmware. And finally Changed the SSD from Non e Version. But no luck.
Still same issue.
Any advice.
Thanks once again.
tsbservice
05-22-2020, 08:52 AM
What is exactly issue now?
mearmi
05-22-2020, 09:45 AM
Machine keeps on rebooting for 2-3 times and then error code appears C-2650
mearmi
05-22-2020, 12:22 PM
Still same issue.
Any advice.
Thanks once again.
Data corruption may have occurred between SSD, MFPB and/or PRCB. Also I'm not sure that Develop has the same firmware as Konica Minolta, even if the model is identical.
tsbservice
05-27-2020, 10:06 AM
... Also I'm not sure that Develop has the same firmware as Konica Minolta, even if the model is identical.
Hmm that may be something. For newer models like 8 series FW from KM should work on Develop analog but on 4 series?
