View Full Version : C554 vs c454 fuser?
mrfuser
05-04-2020, 07:01 PM
Anyone know what the difference is between the c554 and c454 fusers?
emujo2
05-04-2020, 08:14 PM
A2XKR71044--c554
A4FJR70244--c454
Probably wired different and drive gear differences.
adecanmin
05-04-2020, 09:06 PM
Two things. The electrical connection are different. The c554 has much bigger bearings supporting the fuser sleeve roller. The c454 has the small bearings that disintegrate.
mrfuser
05-04-2020, 11:06 PM
Thanks. The C554 has cleaning roller bushings that are toast along with the cleaning roller. Now to find part numbers for ordering . Lots of fun
copyman
05-05-2020, 12:06 AM
Probably the most common issue with the models that use that style fuser.
Brush Cleaning Roller A2XK740400
Teflon Cleaning Roller A2XK740301
Cleaning roller bushing A2XK742901
Brush roller bushing A161771000
There may be new style / color bushings?
Ball bearing 4120550302
The small bearings that disintegrates is used in a lot of finishers, FS 527, FS 534, etc. I take them out to use in these fusers when I strip parts off finishers before trashing.
mrfuser
05-05-2020, 12:21 AM
thank you so much for saving me a lot of time!
Ball bearing 4120550302 (tel:4120550302)
mascan42
05-05-2020, 02:55 PM
Also available as a repair kit HHFRC754E-C754A, used for 554, 654 and 754 models. Recommend using hi-temp grease on bushings.
copyman
05-05-2020, 07:36 PM
Also wanted to add I've seen both cleaning rollers removed and machine ran 100's of thousands prints with no fuser issues. All single side of course, don't think it would hold up well with a lot of 2 sided.
I've personally left the cleaning rollers out out for a few weeks while getting parts and returning. No unusal build up on rollers, etc. Rollers look fine. Think you could leave them out permanently on high volume account that run mostly 20lb plain paper single side only, but don't hold me to it:confused:
copier tech
05-05-2020, 07:38 PM
I usually remove that cleaning roller ass'y when they start to wear out machine runs fine without it.
srvctec
05-05-2020, 08:20 PM
The whole assy. with both cleaning rollers or just one of the roller assys? If just one of the rollers, which one? We've never tried removing either of them so I was wanting the inside info. :cool:
copier tech
05-05-2020, 08:37 PM
The whole ass’y once they dry out it wears the pressure roller also squeaks so we simply leave it out.
AL parts
05-07-2020, 02:39 AM
The pressure rollers of the two models are different, the fixing film is different, and the sponge roller inside the fixing film is also different
femaster
05-09-2020, 08:00 PM
What we do is just remove the brush roller assembly once that bushing wears out on it. It's as simple as removing the 2 small springs and 1 E-clip. The brush roller assembly then slides to the side a little bit and comes right out. Have never had a problem with dirty pages because of removing the brush roller.
mrfuser
05-09-2020, 08:16 PM
I took out and left out the brush roller and ordered a new one. Good to know it’s not vital
