View Full Version : print quality kyocera taskalfa 3051ci
Nikola Karamanov
05-07-2020, 03:26 PM
Hi everyone! I have this issue with taskalfa 3051ci only with magneta and black colors. I have done drum refresh, developer refresh and calibration but with no success!
45619
craigster
05-07-2020, 03:42 PM
I would pull developer units and check mag rollers
kyotechnz
05-07-2020, 09:22 PM
Have had a fair few of this problem. When I see this I replace both the drum and dev for that colour.
Never found out what causes this.
Nikola Karamanov
05-08-2020, 03:21 PM
The problem was from developer roller side, not from the drum!
blackcat4866
05-09-2020, 01:52 AM
It's the developer spacers cracking. Magenta and black developing units will do the trick. =^..^=
kyotechnz
05-10-2020, 09:24 PM
I replace both because from my experience with this fault the problem reappears if I replace just the dev or drum. The local Kyocera rep couldn't tell me the cause but Kyocera has supplied replacement drums and devs as the copiers were still under warranty.
Ropariva
05-10-2020, 10:11 PM
As per Blackcat. The spacer rollers (black rollers) wear on the shaft reducing the gap. Later devs and hi speed machines used a white nylon roller which didn’t wear.
Scott
05-11-2020, 03:17 PM
Charge rollers
Phil B.
05-11-2020, 04:00 PM
Charge rollers
already diag'd as dev units.
