View Full Version : Bizhub C554e
afterhours
05-08-2020, 08:29 PM
Does anyone know if there are special rollers that can be ordered to feed NCR with out it leaving a tire mark?
Please help
Woxner
05-08-2020, 10:38 PM
none that i know
Synthohol
05-08-2020, 10:57 PM
NCR paper isn't supported anyway.
Bricorley
05-08-2020, 11:49 PM
try having them print on thick 1. Should do the trick
blackcat4866
05-09-2020, 01:37 AM
AFAIK vacuum feed is the only way to pick up NCR without marking it ... not available with the C554e.
Bricorley
05-09-2020, 03:59 AM
Maybe Im getting lucky... I have 2 print shop customers who both use a c552 and c654e with NCR. I suppose it depends on the thickness of the sheets
copier tech
05-09-2020, 11:01 AM
Please help
Have you tried using the bypass ?
3ktlc
05-11-2020, 03:12 PM
We use the bypass on ours and set it to thick 1.
