blackcat4866
05-09-2020, 02:32 AM
First time I've seen this:
Simplex prints fine. When duplexing the first three first-sides pass fine, but the first second-side snags in the inverter gate.
I'll skip the misadventures that led me to the right place. With the upper part of the right door removed (but the fans have to be plugged in or you get "An internal error has occurred ...") you can watch the operation of the inverter gate.
When the third first-side is passing the gate about halfway along the inverter gate should shift, to direct the first second-side to the exit. The inverter gate was lazy and shifted after the first second-side passed back into the duplex path for another image.
45623
The return spring for the shift solenoid is kind-of unique ... it's not often that I can't find a suitable spring from my miscellany, but if you unhook the loop and hook two coils further in, the gate moves much more spritely. Just thought I'd share. =^..^=
45623
