View Full Version : Konica Minolta C364e- Blank print outs
Francisca
05-11-2020, 04:26 AM
Hi guys,
I have a C364 here, giving me blank print outs. I did replaced the solenoid but it doesn't solved the problem.
Please could you guys help give me some tips on this.
Hi, what are the consumables in consideration?
How many pages did this C364e make? What is the toner container in? What about the development unit? It could have problems with the laser unit or anything else.
Give us more details.
good job
tsbservice
05-11-2020, 01:59 PM
If only black is missing and you changed SD4 without success you may have problem with developing unit drive. Mark mag roller and check to see if it rotates.
If not drive gears may be stripped.
GIUBOSS
05-11-2020, 02:35 PM
Hi guys,
print do you mean copies too?
copier tech
05-11-2020, 07:01 PM
Hi guys,
What colours are missing 1 or all?
If you stop the machine do you have any image in the transfer belt or image units?
Jumping Jack Flash
05-12-2020, 08:44 AM
Print the demo test 3 times from the user level and check if the machine reports warnig
tsbservice
05-12-2020, 09:16 AM
Interesting, what is purpose of this test? Can you explain a bit more.
Francisca
05-15-2020, 07:28 AM
All colours are missing.
Yup, i did checked the transfer belt and the imaging units but there's no images or even toner particles on them .
Francisca
05-15-2020, 07:49 AM
Ok.
How could you expect me to print the demo page test 3 times on the user level.
When i'm actually having problem with the blank print outs and copies.
I did print the demo test and meter count pages but its all blank.
:confused::confused:
Francisca
05-15-2020, 07:55 AM
Yes both print and copies.
tsbservice
05-15-2020, 08:23 AM
Try to replace High Voltage Unit.
Jumping Jack Flash
05-16-2020, 03:19 AM
Does the machine display any warnings? type P9, P28 ... after testing.
If so, then probably the HV Unit is damaged
Jumping Jack Flash
05-16-2020, 03:29 AM
The machine checks the coverage on the transfer belt every 3 prints.
warnings give information if the cause is a laser.
EarthKmTech
05-16-2020, 03:51 AM
Every single time i’ve seen this, and its been many - it was the HV board.
Ensure the new one is not also destroyed by ensuring there are no hv shorts.
Ie developer contaminated 2nd transfer roller, filthy belt internals, consumables in terrible condition.
Francisca
05-18-2020, 03:54 AM
I have able to figured out the fault with your tips.
I've swapped the high voltage board (HVB) from a working Konica Minolta C364e and the copier is printing okay now.
Thanks very much for all your kind assistance.
Appreciate y'all
Jumping Jack Flash
05-18-2020, 09:42 AM
Appreciate y'all
Maybe this information will be useful to anyone.
You can try to fix the HV by replacing the components marked N38 with new ones.
They can be measured and checked as a fuse.
Francisca
05-19-2020, 12:21 AM
I've tested the continuity of the components and found out that its not the N38. Its the F103 which is faulty.
I'm going to replace it with a new one.
This would help save the cost for buying a new HV unit.
Thanks a lot.
