View Full Version : Bizhub 363 is not booting, only hourglass continue
Simza
05-11-2020, 06:06 PM
Hi comunity
i have problem with bizhub 363, which i have created myself. I have updated the firmware and the elctrecity was gone. Because somebody have take the power switch off.
So now i try to start the BH 363, but it shows only the Hourglass continue. please tell me what shuld i do to solve the problem.
I will be glad, If anybody can provide me NVRAM Reset tool for Bizhub 363series.
Thanks in advance for your help.
Have a good time and Stay Safe
copier addict
05-11-2020, 08:42 PM
Hi comunity
Just do the firmware upgrade again. That should bring it back.
Simza
05-13-2020, 01:35 AM
Hi Friend,
thank you for reply.
I have try many time to install the firmware again, but it shows only hourglass.
I have also try to change the NVRAM with outher copier (BIZHUB 363), but the result is the same.
Is it possible to rebott the MFP Board only.
I have also try with troble rest. Nothing is working:mad:(Only hourglass)
Is there a software for MFP troble reset?
The MFP Board have 2 USB slots onboard, can you tell me how can i use this slots maybe.
Normaly i know the 3 series very well. But troble like this would never created.
Stay Safe
Simza
05-13-2020, 07:42 PM
Hi,
can anybody provide me Reset tool for Minolta Bizhub 363.
Thanks,
Stay Safe
FrohnB
05-13-2020, 07:59 PM
Hi,
Thanks,
Stay Safe
I believe You must have access and credentials to a secure Konica Minolta web site, and will need a tech or KM representative to come out and make sure they agree with your diagnosis.
Also, your post is a little strange. You say you updated f/w and killed the machine, but in the same sentence you say that someone may "have take the power switch off", and then continue to confuse by saying you can power up and get the hourglass??? Then go straight to asking for an NVRAM reset tool???
Smells a little Fishy to me!
copyman
05-14-2020, 02:45 AM
[QUOTE=FrohnB;1474309]I believe You must have access and credentials to a secure Konica Minolta web site, and will need a tech or KM representative to come out and make sure they agree with your diagnosis.
Smells a little Fishy to me![/QUO
Obviously there is a language barrier with this post. I read it that while he was updating firmware the power went out and now when he powers on it is stuck on hour glass. Sounds very possible to me.
If the original poster is a tech or $ contributer PM me your email address and will send you reset FW.
copyman
05-14-2020, 02:47 AM
Obviously there is a language barrier with this post. I read it that while he was updating firmware the power went out and now when he turns on it is stuck on hour glass. Sounds very possible to me.
If the original poster contributes a small donation to this forum and sends me PM I will send you reset FW.
Simza
05-14-2020, 01:25 PM
Hi Fiends,
i am used copiers dealer in Germany since 2002.
We are not working with Konica-Minolta, ricoh...... directly as a technican.
We buy copiers in big quantity, check, make testcopy and sell it out in outher contries.
Sometime we sell also in local market. Then we refurbish the total copier and give 1 year warrenty.
I am here to lern somthing from professional technicans:cool:
My ENGLISH is not the best:o but if anybody can German Lenguage, then i can explain my problem much better;)
Whatever, its ok when you say what you mean. I will arrange the NVRAM Reset tool also in Germany, but it takes a little time.
I have Change the MFP Board by the Bizhub 363 and it works.
I have more then 20 machenes from Bizhub 363.
I like to know ONLY how can i solve this Hourglass problem with technical know how.
Thanks a lot, Take care and stay safe
copyman
05-14-2020, 05:16 PM
Hi Fiends,
There is a member on this forum name Hans. Think is living in Germany now. He knows Kon/Min very well. Perhaps send him a PM and introduce yourself. He sells the best UFR for the C223 series.
Copier repairman
05-18-2020, 03:21 PM
Hi comunity
Fighting!
I wish you victory ..
Simza
06-03-2020, 12:41 PM
Hi,
thank you very much for your support,
i have clear the problem with recovery tool.
1-Copy NVRAM on MFP-Board(Working copier)
2-take the NVRAM out and put in the dead copier. Started it with recovery tool. There was option to recovery. So i have put the data from good nvram to the MFP-Board....
3-Clear the licence error
4-install Moviedata
Copier was working
Have good time
Simza
05-06-2021, 03:26 PM
Hi,
i have teh same problem with bizhub 223. It shows constantly hourglass.
I have try to solve with "A1UDFW.TAR". but it dosent work. ( using 2gb FAT32 USB stick)
I have try tec.-slot and normal usb. Nothing works.
Any idea?
