View Full Version : Miscellaneous Develop Ineo+ 224 Error C-2650
mearmi
05-14-2020, 07:30 AM
Getting Error C-2650 in Develop Ineo+ 224
When turn on the printer it reboots 2 times and then getting error code C-2650
In Service Manual it says Main Back Up Media access error.
Trouble type C2650: Main backup media access error
Rank C
Trouble detection
condition
• The re-written data, which has been read out, checked and founded as error, is read out again and found as
error.
• The error was found when reading out the counter value.
• The main body detects that the EEPROM is not mounted.
Trouble isolation -
Relevant electrical parts • EEPROM/1
• EEPROM/2
• MFP board (MFPB)
Kindly advise.
Many Thanks
tsbservice
05-14-2020, 08:17 AM
mearmi, if your Develop crosses to bizhub C224 then FWs GA8-K5 and GB8-K5 are suposed to deal among other issues with that error.
Be careful to read attached info before attempting to update FW as there are many restrictions.
mearmi
05-14-2020, 08:33 AM
Thanks for your message. Tried updating the firmware (M1). But getting error Invalid Memory. Tried 3 usbs with the same error.
In Initialization. After clearing all Data : Machines works for 5-10 prints then reboots with the same error code.
Please advise
tsbservice
05-14-2020, 09:09 AM
Try to update FW with front cover open.
mearmi
05-14-2020, 01:08 PM
Tried but didn’t work. Display freezes at 2 bars
waited for about 30 minutes.
mearmi
05-14-2020, 02:47 PM
What do you advise?
Synthohol
05-15-2020, 12:35 PM
reseat the SSD board.
tsbservice
05-15-2020, 01:08 PM
Agree, also reseat and clean memory DIMMs.
mearmi
05-24-2020, 09:34 AM
Thanks a lot everyone.
Re seated SSD , Changed the RAM. Updated the firmware. And finally Changed the SSD from Non e Version. But no luck.
Still same issue.
Any advice.
Thanks once again.
mearmi
05-25-2020, 10:37 AM
[QUOTE=mearmi;1483736]Thanks a lot everyone.
Still same issue.
Any advice.
Thanks once again
Synthohol
05-25-2020, 04:36 PM
other than changing the MFPB as a last resort, run an engine data backup in service mode, backup the address book if allows and use the SSD reset tool following the explicit instructions so to not lose counter data and ensure a proper restore/recovery. (including entering the 2 digit machine type during the process)
if you need documentation let me know.
