View Full Version : CQ Offset copies
jayw
05-20-2020, 04:23 PM
I have a TA-6002i that is making off offset copies or residual images but it only happens first thing in the morning. The fuser and transfer unit has been replaced. The Regional tech recommended that I replace the Waste Toner Box(302ND94013) in the rear of the machine which I did. It seemed to have fixed the issue but if the machine sits overnight, the first 5 copies come out with the residual image then it clears up.
Has anyone else had this problem?
Phil B.
05-20-2020, 05:01 PM
you need to properly register .. your profile is incomplete.. your terminology isn't accurate either..
are you a tech?
blackcat4866
05-20-2020, 10:51 PM
Samples?
Residual images of what? previous prints? registration marks? something else? is there an interval?
Mr Magic
05-21-2020, 03:54 AM
Please provide more detail. Does it look like watermarks? Could be condensation! But still, would need to see!
All the best!
jayw
05-28-2020, 09:14 PM
I got the terminology from the service manual. 5-11 Offset. This is what I believe is happening. I also checked the Repetitive Defects Gauge in the appendix of the manual. When I measured the defect, it appears as if it's the fuser which has been replaced.
jayw
05-28-2020, 09:16 PM
Also, I tried to register my profile but I don't know where to go.
Luther
05-28-2020, 09:38 PM
if the machine is in silent mode , turn it off and see if the problem goes away
blackcat4866
05-29-2020, 01:27 AM
Do you have the appropriate media type set for the paper you're using? =^..^=
Phil B.
05-29-2020, 02:12 AM
Also, I tried to register my profile but I don't know where to go.Ok sent you a PM earlier today.
Follow that and answer in public forum here.
It will give us better info to help you
