View Full Version : 4052ci Strange inner finisher issue.
JR2ALTA
05-26-2020, 10:39 PM
I have an inner finisher DF-7110 exits one sheet the exit tray lowers to bottom position. Message "main unit inner tray full of paper". I guess I went off half-cocked and ordered the finisher upper and lower limit sensors. Which didn't fix it.
So I removed the inner finisher so the customer could use it while I researched and ordered more parts. After I removed the finisher I got the same message. I figured the machine now needs a exit switch (which is removed and disposed of when installing the DF-7100) So I tripped the sensor and the machine was happy.
Now that I am ready to go back, it occurs to me. Why would the machine say "main unit inner tray full of paper" when there's a finisher installed? Shouldn't it say "exit tray full of paper" or "finisher tray full of paper"??
So that got me thinking, is there something in the inner finisher that's supposed to trip that main unit sensor? or does the machine bypass that sensors when it knows a finisher is there?
Anyone seen anything like this? Still not sure if I have a machine issue or a finisher issue... Oh well, will keep this thread updated.
Thanks in advance.
blackcat4866
05-27-2020, 01:11 AM
I'll have to look up the details tomorrow. I think it was a 4052ci with a bridge and external finisher, but similar symptoms.
The precipitating event was their IT wiping all the PCs and letting WSD install generic drivers. Those drivers did not configure correctly, so the machine tried to eject all paper to the engine top ... but it couldn't ... it jammed every page. Whomever had installed the bridge had removed and thrown away the exit guide and flag for the lower exit. For the first year it had exited to the finisher without an issue, and never tried to exit to the engine top.
Naturally we didn't have those parts lying around, so I had to order them. I had never even looked at the exit assembly until that day, so I had no idea what it was supposed to look like. Later on we got the proper drivers installed. =^..^=
KYO_OEM
05-27-2020, 08:48 AM
Do you remember step 5 from installation manual for DF-7100?
If you forget to remove the actuator extension, you can get this problem.
45744
JR2ALTA
05-28-2020, 12:16 AM
Well, lol, that extender was installed. But that didn't fix it. It was the paper pressure actuator being out of place. It those 5 or 6 arms that fall fowards onto the paper on the exit tray. I guess i always figured they helped stack the paper. But they actually determine the height.
nathicana
06-09-2020, 09:21 PM
Can you please give more details on the problem with the pressure arms and how did you put them back?
Do you know what senses the height of the paper stack in the finisher tray?
I'm trying to help a tech who is having the same problem. He says he can pull the pressure arms down and let them go back. His "main unit inner tray full of paper" message will not reset.
He's also getting C8800 DF communication error. Besides the bulletin do you know a way to make the connector fit better?
J-Tin
06-13-2020, 04:18 AM
Install washers around the screws between the finisher's electronic connector and the frame behind it to reduce the wiggle and improve the connection. This has worked on dozens of these machines.
If its stuck on the inner tray full message, it is likely because the finisher isn't being recognized due to the poor connection. When this happens, turn power off, reseat finisher and power on. On the copy screen, the image of the copier should show that there is an internal finisher installed. If not, it isn't connected well enough.
JR2ALTA
06-13-2020, 05:22 AM
The arms (as they were visible) seemed OK but they didn't move smoothly. I took off tray, front and side covers to find the whole actuator ass'y was off on the rear side. Fixed and the "paper full" message fixed.
