View Full Version : I-series colors off at install
mascan42
05-28-2020, 06:01 PM
I've run into this problem on a few of the compact i-series machines (C4050i/3350i). Upon install, the internal demo page shows the color bars off a bit (red is slightly orange, green is more of an olive green). Running gradation adjustment doesn't help. The customers have been living with it for now, probably not even noticing since they're low-volume desktop machines. Any idea what this could be?
Synthohol
05-28-2020, 06:24 PM
OEM toner? just asking.
color is crappy, i agree.
tsbservice
05-28-2020, 07:07 PM
OEM toner? ...
Off topic:
Rofl, really you dare that :D
Back on topic.
My apologies to TS. Had only few in the field. I-series are not what used to be especially comparing A4 models to older A3 models.
qbert69
05-28-2020, 08:36 PM
I've run into this problem on a few of the compact i-series machines (C4050i/3350i). Upon install, the internal demo page shows the color bars off a bit (red is slightly orange, green is more of an olive green). Running gradation adjustment doesn't help. The customers have been living with it for now, probably not even noticing since they're low-volume desktop machines. Any idea what this could be?Sounds like it's a bit heavy on the yellow!!! You should be able to manually dial the yellow down a notch or two in service mode & then lock it in!!![emoji41]
Sent from my SM-N950U1 using Tapatalk
rrrohan
05-29-2020, 07:35 AM
the C3320i series have a bulletin high TCR.
Also i found with the C360i the GDI demo page colours looked off until i re did stab with good quality paper instead of the crappy office paper most offices use
Bix
05-29-2020, 08:22 AM
I've found toner in the glass of the laser unit several times, so try cleaning it with your magic wand.
EarthKmTech
05-30-2020, 01:41 AM
I series did introduce more vibrant colour palet aparently - it can be disabled and there is a bulletin on it somewhere.
It was mentioned to change it back if the customer prefers the printed colours from the older series machines.
Not very helpfull but i remember someone mentioning this.
gareth577
05-31-2020, 09:49 PM
You can return to the conventional color reproduction by using Soft Dip SW 153, bit 6 (Hex 40)
After setting the softswith please Initialize and Image Stabilization followed by Gradation.
ivovb
06-03-2020, 09:32 AM
Use latest firmware G00-7D. Two of the predecessors targeted a print quality proplems.
BR
tsbservice
06-03-2020, 05:10 PM
Agree on that. Also under PCL driver “Image Quality Setting” default Document/Photo corresponds to what Konica call “Memory Color”.
They KM have stupid theory how adoption of color matching that corresponds to “Memory Color” will make user experience better and so bla-bla.
Basically making colors more vivid than real like on some smartphones, etc.
