View Full Version : Konica minolta c353 problem scan FTP format hard disk
enricocopyline
06-01-2020, 06:16 PM
In a konica minolta c353 after the logical formatting of the hard disk i can't scan ftp.
HD is installed
what does depend on?
Phil B.
06-01-2020, 06:23 PM
HD is installed
did you reload the system and others software on the HDD?
what made you reformat the drive?
enricocopyline
06-01-2020, 06:37 PM
I formatted for an error
what do you mean by reloading the software?
Phil B.
06-01-2020, 06:41 PM
you are over your head on this job. if you don't understand what " reloading system software is "
enricocopyline
06-01-2020, 06:49 PM
I have always formatted hard drives and have always worked quietly after formatting
you intend to reload the software with the flash card?
quiet I am able to do everything
emujo2
06-01-2020, 07:02 PM
What was the original error that made you do a HDD format..?
enricocopyline
06-01-2020, 07:48 PM
c-d004
emujo2
06-01-2020, 08:12 PM
run the diagnostics..
Go to [Service Mode] -> [Sate Confirmation] -> [HDD Adjust] -> [Memory Check]
If they get a NG, replace parts. (See below).
WORK0 = Replace Standard Memory (DIMM1).
WORK1 = Replace Expanded Memory (DIMM2).
FILE0 = 1 Memory of ASIC200 installed in the MFP board.
copier addict
06-01-2020, 08:19 PM
There isn't any system software to load after a format. Phil may be thinking of a different machine.
enricocopyline
06-01-2020, 08:28 PM
could there be some characters like (_) which are not supported in the 4series and the dpsw needs to be modified?
copier addict
06-01-2020, 08:37 PM
If it was able to scan via FTP prior to the format there is likely a setting that got cleared. Go back and check all your settings.
enricocopyline
06-01-2020, 08:58 PM
what settings are erased with formatting?
tsbservice
06-01-2020, 09:49 PM
Clearly you need a manual to start, and no, it's not just a matter of formatting HDD when machine errors.
Phil B.
06-01-2020, 10:30 PM
hell I've been able to clear MANY error codes without reformatting a HDD..
don't think the OP has told us WHICH error codes popped...
he just might have made a BIG MESS from a simple problems.
rrrohan
06-02-2020, 06:46 AM
what do you mean by cant scan to FTP? does it give a error or is FTP option not available
457844578545786
enricocopyline
06-02-2020, 09:48 AM
457844578545786
error
today it works with ftp on normal pc
scan to server and to nas does not work
Hansoon
06-02-2020, 10:00 AM
SMB1/SMB3 issue?
Hans
rrrohan
06-02-2020, 12:50 PM
SMB1/SMB3 issue?
Hans
i assume he is using FTP due to the SMB support being phased out for security. plus i doubt email is a option due to SSL/TLS so really FTP is the only option.
you could be half asses and scan to the PC that does work then SMB share from that PC to all the others
tsbservice
06-02-2020, 01:00 PM
Could be wrong but I was told that if you use one PC with SMB1 enabled just to scan from older models, one cannot access this PC shared folder from other SMB1 disabled PCs in the network.
rrrohan
06-02-2020, 01:07 PM
yeah but he would be using FTP to the one PC that mysteriously works to then share presumably with SMB2 to all other PC's
emujo2
06-02-2020, 01:18 PM
I may be worng here..but if you format the HDD you also delete any installed SSL certs..Possibly this is why he has the dreaded "it worked before I did this" statement. E
